Trunk to Cisco CUBE is down
Hi, I’m trying to build a SIP trunk to a Cisco CUBE however FreeSBC is reporting the NAP as being in the “Unavailable nap list”.
I have run a debug on the Cisco side and I can see SIP option messages being received and replies are being sent.
Can anyone offer an advise?
Thanks in advance.
Looks like the Cisco will source the SIP option packets from a port other than 5060. When you define the NAP it creates an ACL for the remote device but only for port 5060. I had to manually create an ACL for any port from the IP of the Cisco. Now the NAP is available.
Thanks Serdar on technical support.
It is also worth note that when you send calls from the Cisco CUBE that calls are sourced from a random port number. When configuring the NAP by default the “Filter by proxy port” option is checked. This means the the NAP will only accept the call if the source port is the configured value (5060 by default). Looking at the call trace I was seeing “No NAP found” this is because the NAP would not accept the call from the random port.
