I’m having trouble setting up a SIP TLS profile so that remote clients can connect to the SBC using TLS. Do you know if it is possible to use Let’s Encrypt?
I see the message ‘Could not initialize SSL context’ when activating the configuration.
I have tried using the Let’s Encrypt certificates from Chains of Trust - Let's Encrypt by adding the root certificate as Trusted and added the Intermediated certificates. I also copied the contents of cert.pem for my domain generated by the Let’s Encrypt command line tool as an Intermediate certificate. I then added all of those to the Trusted Certificates option in the TLS profile. Is this correct?
I’ve read those instructions and watched the videos on the Telcobridges YouTube channel. The examples there are more for connecting to another server as a client using TLS where I want to accept registrations over TLS and forward them to Asterisk.
Suddenly, that error went away though. Looking at the log under /log_actions, I didn’t change anything between activating the configuration. Maybe I modified the private key on the file system, but I’m not sure. I was even getting it using the ‘Default’ local certificate in the TLS profile.
Anyway, I got it working after a lot of trial and error. Here are my steps if it helps anyone:
I entered the certificate generated by Let’s Encrypt (cert.pem) of type Local into FreeSBC.
I copied the private key (privkey.pem) to /lib/tb/toolpack/pkg/ssl_certificate after converting the private key to RSA format (openssl rsa -in privkey.pem -out rsa.key). This file has to have the same name as the Local certificate with ‘.key’ appended to it (ie. If the certificate is named ‘domain’, the key is named ‘domain.key’).
Then create/edit the TLS profile and disable “Require peer authentication”. Choose the local certificate as the Local certificate you copied from cert.pem. Then add the two intermediate certificates from Let’s Encrypt to the Trusted Certificates in the TLS profile.
Edit: Alternatively, you could just put the contents of chain.pem into an Intermediate certificate on FreeSBC then add that to the trusted certificates for the profile instead of using the certificates from Chains of Trust - Let's Encrypt
I am sorry to bring this back up to life, but I haven’t been able to find anything else to help. I have followed the instructions, but no matter what I do I cant get the file uploaded to /lib/tb/toolpack/pkg/ssl_certificate. I am at a loss on how to get it done. I am trying to use WinSCP and I am hosting on Azure with SSH permissions enabled. I am trialing FreeSBC, but I want to know I can get this done when I go to ProSBC. Any help would be appreciated. Thanks!
