This filter is used to:
Call arrives TMG, checked the flag: http_routing of the incoming NAP, if it is set to YES, continue the next steps!
Send query with incoming NAP name, calling and called number to an external routing engine server : a URL LIKE https://192.168.2.100/api/routingengine/routingengine.php… as an example
Get required parameters: dest_nap, priority, weight from the external routing engine server:
a. For valid call with routes: 200 OK with response like below:
“route1”:“NAP_A”,“priority”:5,“weight”:100,
“route2”:“NAP_B”,“priority”:6,“weight”:100,
“route3”:“NAP_C”,“priority”:7,“weight”:“100”,
“route4”:“NAP_D”,“priority”:8,“weight”:“100”
b. For invalid call, 404 no route -
Compose the routes by the returned string
Combine the Routes with the route from the ProSBC Routes configuration
http_query_to_external_routing_engine_in_post_format.zip (2.5 KB)
