Questions about FTP and CDRs
We are trying to gather CDRs (in text format) from the ProSBC using FTP.
• Do you recommend creating a Web User with Read-only access for FTP?
• How can we restrict FTP access to a single IP address?
• Does ProSBC adjust to Daylight savings automatically? What will happen to the CDR logs when clocks change during fall-back and spring-forward?
The CDR files are stored on the SBC host directly, so it is not controlled by the web portal. So it can’t be done via the webportal
This should be done via your network firewall rule
ProSBC is taking the clock from the Centos host, so if it is set to take it from NTP, it will reflect the time change automatically
https://docs.telcobridges.com/tbwiki/Toolpack:set_date_time_A
