One Way Audio/ No Audio Problems
One-way Audio/No Audio is a common VoIP problem. It is one of the most frequent support questions we receive. There are many possible causes.
  • Outdated firmware in routers, VoIP phones, Firewalls, etc. can cause one-way audio. Ensure you have the latest updates for all the devices in the call path.
  • Firewall mistakenly blocking RTP, be sure firewalls configured correctly
  • Particularly if NAT is involved in the call path, configuration of the various devices may be a problem. Please click here for NAT configuration on Telcobridges devices
  • Another reason for one way audio is having your system set to offering unsupported codecs within your other SIP systems.
  • Just as each side of a call must send RTP within the same codec, each side must also have the same phase timing (or ptime value). Profile SDP Description
  • Configured RTP port ranges can cause a problem too. Check FreeSBC and endpoints (Clients, SIP Trunks) are using correct RTP ports. RTP Port Range
  • High one-way packet loss. If sufficient packet loss occurs in one direction on a call, that half of the conversion may break down, but not cause the entire call to drop. Packet loss can occur due to a number of reasons:
    • High utilization on a link with no QoS.
    • Misconfigured interface: Half-duplex or duplex mismatch.
    • Underperforming network devices.
    • Cabling faults.
  • Wrong threshold configuration under SBC Advanced parameter can cause FreeSBC to block RTP-Audio by the firewall due to thresholds. You can see the following error in your call trace;
    ** Data path error;
    -Blocking all packets due to excessive packets/bandwidth from network
    Please double check your thresholds configuration from;
Code:
SBC -> Advanced parameters
Please check the following wiki for more troubleshooting steps; FreeSBC Troubleshooting Guide
