Need some help with a fresh install
We got 2 ProSBC keys in order to set up a HA pair.
I made 2 VMs on Proxmox hosts, and installed from the provided ISO. After installation, I get warnings on both hosts saying that “No valid host or adapter license found. Click here to upload a license.”
I am also trying to figure out how to setup the public IPs and how many I need. We have 2 ISPs at the site, so I would like to use both for redundancy.
For now, I configured 5 interfaces on each VM: 1 mgmt, 2 ctrl, 2 voip.
I see that once the HA got built, I have the 2 voip interfaces functioning as the HA node. Should I add 2 more, and have an outward and inbound facing IP from each provider?
Thank you,
Alex!
Q. After installation, I get warnings on both hosts saying that “No valid host or adapter license found. Click here to upload a license.”
After clicking ‘Get or renew license links’ they get activated automatically. Then, download and import both licenses.
Q. For now, I configured 5 interfaces on each VM: 1 mgmt, 2 ctrl, 2 VOIP.
I see that once the HA got built, I have the 2 VOIP interfaces functioning as the HA node. Should I add 2 more, and have an outward and inbound facing IP from each provider?
  • For the interfaces, Your IP interfaces seem ok. You have mgmt. ports for each SBC and CTRL0 and CTRL1 for HA. VoIP0 and VoIP1 are shared by two SBCs.you can add more interfaces if you need. At the moment 2 interfaces are enough for almost all use cases. In fact, you can also use the same IP interface for both carriers as long as they can be reached by each other.
Thank you!
I activated the linceses and we’re proceeding with the setup.
Thanks again for the info!
