For a long time, we are experiencing a strange issue on our baremetal installation of ProSBC (3.1.147.16).
Whenever you make a modification on any IP interface/address, a large number of NAPs goes down, even if the changed IP addresses have no relation to the NAPs in question.
Once the NAPs have gone down, besides rebooting the ProSBC, another workaround that sometimes helps is to go into any IP interface, modify the IP address temporarily, activate the configuration, then revert the IP interface back to previous/correct settings. This seems to be helpful about 95% of the time.
We are at our wit’s end with this issue. It has been reported to TelcoBridges before (in the previous support model) but it was not resolved (perhaps we were unable to get it communicated correctly
). So while we might be able to request management to purchase support, the concern is - could we be sure it will be solved?
Something I have observed is that it is less likely to happen if the proxy address set in the NAPs is exactly the same as the Gateway IP address specified on the IP interface.
The physical interfaces on the server are as follows:
04:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM5720 2-port Gigabit Ethernet PCIe
04:00.1 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM5720 2-port Gigabit Ethernet PCIe
18:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
18:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
18:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
18:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
For SIP/RTP, we are using three of the I350 ports (one is facing our softswitch, one is facing customers connected over the internet, and the third is facing customers connected over point-to-point links). One of the BCM5720 is used for management.
We are now wondering if the BCM5720 be the cause of the instability, although the documentations seems to suggest that the NIC whitelist is only important for SIP/RTP?
If anyone has any idea/suggestion, we would appreciate it. Can provide any additional information that may be helpful.
