Multi-Tenant PBX Support
Hi team,
What’s your plan to support multi-tenant PBXes? At the moment, the way your system is designed seems to be more suitable for single tenant systems.
Kind Regards,
Asanka
Hi Asanka,
FreeSBC does support multiple domains and multiple registrars in one system, all possible from one single destination IP and multiple SIP ports, thus multi-tenant PBXes shall be supported in this way.
Best regards,
William
