How to convert a standalone system into 1+1 setup
The standalone system is working very well and I want to know how can it be converted into a pair of 1+1 setup.
I remember in the first page, the SBC is already configured in the wizard as “Standalone” or “Redundant” setup.
Do I need to reinstall the entire SBC in order to get back to that step? what would be the best options here?
Hi Bronze
You can reset a standalone system host role and configure as 1+1 system. To do that please go to Hosts → Status → Select the hostname. From Host Control Action section select Reset Host Role and apply. The standalone system will reboot with configuration wizard again and you select the role of the system again. Please check the following link
https://docs.telcobridges.com/tbwiki/FreeSBC:1%2B1_Configuration
Thank you very much!!! That’s very helpful!
