Hi guys!
After the setup in barematel, my ip routing table this seem below!
But, i dont link to access the internet, becouse the default route (0.0.0.0) it setup in my mgmt0 (my private LAN), how can change this?
Hi guys!
You can use the tbchangeip command to change mgmt interface-related IP settings. The other IP settings for VOIP can be added/modify by web GUI. for VoIP interfaces you don’t need to create a route at the CentOS level. The routing is done by our tbrouter application.
