History-info routing scripts
We have an agreement with Turk Telekom (Turkish Landline Operator). With the agreement their landine subscribes can be ported to us and became our subscribers with no change in their landline and connection. When the subscriber initiates a call. Turk Telekom sends this call to us from the interconnection. We receive the call at SBC side and send the call to our softswitch. If the CLI ise subscribers CLI, there is no problem in authentication on Softswitch. BUT, if the subscriber diverted his number to another number; or sends the call as “anonymous” the calls comes with the calling party number or as “anonymous” and we cannot authenticate the call with the incoming CLI.
They are also sending the original subscriber number in history-info header like History-Info:tel:03125040054;index=1
So in order to be able to authenticate on softswitch I do want to send the called party number as “SubcriberNumber#CalledNumber” so I can check incoming CLD in softswitch and can authenticate the call.
Is there any suggestion how can I do this with the scripts?
Thanks in advance
Cenk Keylan
3C1B TELEKOM
Hello Cenk
You can check our script examples in the link Routing Scripts and find our script development wiki in the link: https://docs.telcobridges.com/mediawiki/index.php/Routing_script_tutorial:Mini_Development_Guide
If you want Telcobridges to create a special script for you please contact your resellers.
I am sure that many people can check these scripts and make a new one for own usage, but when I look I understand nothing :frowning:
In this case, we can help you with 9x5 support hours. Please contact your reseller.
I’ve reached out to them.
