Grouping naps (limit number of calls)
is there a way to set a common limit for multiple NAPs ? In particular limit number of calls.
For example I have NAPs A, B, C. I want a limit of 1000 calls across all NAPs A,B,C. So I cloud have a situation like 900,90,10 calls or 333,333,333 both within a limit of 1000 in total.
Hi Andrzej
You can set the limits on the NAP base. You can configure it from NAPS → Select The NAP → Advanced Parameters → Call Rate Limiting.
