This scipt is used to add or replace the SIP header X-AUTH-IP from the incoming call source IP to the outgoing call:
- X-AUTH-IP: (ip address of the incoming call leg) Freeswitch can be configured with apply-proxy-acl, that only allows listed proxy with the header X-AUTH-IP
It is used to identify accounts original IP.
sip_header_auth_ip.zip
(2 Kb) Downloaded 33 times
