Enable/Disable Session Timers Per NAP
It would be great to be able to enable and disable Session timers per NAP.
I know it can be done globally at the SIP stack level, but getting this feature as an option within either the NAP config or the SIP Profile config would be nice.
Hi Gardar,
You’re right — session timers currently exist only as a global on/off at the SIP stack level (Configuration > SIP Stacks > select stack > “Use session timer”). There’s no per-NAP or per-profile override today.
Current workaround: Use separate SIP stacks. You can create multiple SIP stacks, each with its own session timer setting, and assign different transport servers (and thus NAPs) to each. If you have a carrier that needs session timers and another that doesn’t, put them on different stacks.
That’s a reasonable product request — the SIP profile would be a natural place to add this, since it’s already the per-NAP container for SIP behavior. We will review.
Thank you,
Dave
