Domain Rewriting
Is it possible to change the domain/realm for messages as they pass through the SBC?
e.g. I would like a remote user to register with the domain mypublicip.com and for that to be forwarded to my local PBX as myinternalip.com ?
Thanks,
Tailor
It is possible to do that. You need to use Regex in the remapped called/calling numbers in your route. Pleae check how to use Regex from the following link;
https://docs.telcobridges.com/tbwiki/Toolpack:_How_to_Use_RegEx_in_Remapped_Called_and_Calling_Number_Mask
