This shows how to add White or Black listing to any Routing scripts. With this script, any called or calling number prefix can be blacklisted or whitelisted. This script can be assigned globally or per NAP. For this you choose the “scope” to be “global” or “per_nap”. It also reads a .csv file which has the called and calling number list (default name ‘black_white_list.csv’). A blacklisted called number set globally will block anyone trying to reach that number (or number prefix). A whitelisted calling number will only allow calls from these calling numbers in the system - all other calls will be dropped.
To set up a Filter, the main script needs to be modified. The main script can be either simple_routing.rb or any other script.
First, go to the routing script section of the Web portal
Code:
Gateway -> Routing scripts -> Example Scripts -> simple_routing.rb [Edit]
Three things need to be added. At the start of the script:
Code:
require 'black_white_listing'
In the main class:
Code:
include BlackWhiteListing
Code:
before_filter :method => :black_white_listing, :scope => :global
The final script will look like this:
Code:
require 'base_routing'require 'black_white_listing'class NapGroupAndWeightRouting < BaseRouting include BlackWhiteListing before_filter :method => :black_white_listing, :scope => :global route_match :call_field_name => :called route_match :call_field_name => :calling route_match :call_field_name => :nap route_match :method => :match_nap_availability route_remap :call_field_name => :called, :route_field_name => :remapped_called route_remap :call_field_name => :calling, :route_field_name => :remapped_calling route_remap :call_field_name => :nap, :route_field_name => :remapped_napend
White and black listing file
The 'black_white_list.csv file needs to be formatted in a specific way. There are 4 columns: The first one is indicating the calling number (or calling number prefix). The second one indicates to whitelist ‘w’ or blacklist ‘b’ the number. The third one is indicating the called number (or called number prefix). The last one indicates to whitelist ‘w’ or blacklist ‘b’ the number.
This example will blacklist the calling numbers 148240000 and 148240707, and also any calls that try to reach numbers starting with 450 or 514 :
calling calling_params called called_params
148240707 b
148240000 b
1001 w
450 b
514 b
To add the white and black listing file to the system
Click FileDB in the navigation panel
Click Import new file
Click Browse and select the ‘black_white_list.csv’ you wish to import.
Click Import
To assign a white and black listing to a NAP
The scope needs to be set to “per_nap”
Code:
before_filter :method => :black_white_listing, :scope => :per_nap
And you need to add new NAP colums to assign the files to the NAPs:
Code:
Gateway -> Routes -> NAP Columns -> Create New NAP Column
Type attributes: dbfile
Default: black_white_list.csv
Don’t forget to activate the new configuration.
In the Call Trace you will see 403 Forbidden for black listed call and you will see following messages in the Gateway logs if call have any blacklisted number;
Code:
11th, 19:22:24.053+1100 TBLV1 GW : CTBCAFGateway::GetRoutes: Found 0 contacts for user/contact '148240707' in domain 'sip.xyz.com'.11th, 19:22:24.053+1100 TBLV1 ROUT: black_white_listing: calling=1001 -> WhiteListed -> Allowing11th, 19:22:24.053+1100 TBLV1 ROUT: black_white_listing: called=148240707 -> BlackListed -> Rejecting
