Activate configuration with TelcoBridges RESTful API
We have the following issue: We are updating/adding phone numbers using web portal (Import new digit map) or TelcoBridges API. But it seems like we need to activate configuration for digit map to work. Is there any way to activate configuration with TelcoBridges RESTful API?
We are adding and removing 50 plus numbers every day and we are doing with API and it is inconvenient to go to webportal and activate configuration after every change.
I guess you are using tbconfig command to update the digit map file?
If so, you will need to load the update, see this link as an example:
https://docs.telcobridges.com/tbwiki/RESTful_API:_Updating_a_Route
Or you can also use tbconfig command to activate the configuration:
https://docs.telcobridges.com/tbwiki/RESTful_API:_Activating_a_configuration
