ProSBC in KVM LAN/WAN voip0 NIC showing down
Just tried to install the ISO image, sounds like freesbc 3.1.145.26 can work well. although i dont have a valid license.
Here is the error in 3.3.12
Hi Julienpeng,
Yes, I see it’s working. You need a license for testing, right? Since this is a FreeSBC version, I will consult my team regarding a license for testing. As you already know, we are no longer in the FreeSBC business. :slight_smile:
I want to help you with your testing phase. Please look at the left-hand menu of the web GUI. At the bottom of the menu, you will see Maintenance; click on.
>> Packages and Licenses
At the top of the page, you will see: Hosts - Serial number - License Seed. Please copy and paste that text here for me. I will help you with a temporary license that you can use for testing.
– Support
Oh and I am curious if you know what platforms are running the KVM on the Huawei Cloud? OpenStack, Proxmox?
Hi Support,
Thanks for your response, It’s ok, since FreeSBC is no longer in the business support, we can wait for the newer version of ProSBC which will fix this issue.
For the platforms running the KVM on the HuaweiCloud, I think it is OpenStack.
Just wonder what’s the difference of the DPDK processing between 3.1.145.26 and 3.3.12?
